If you have checked the "remember passwords" checkbox then you should
never experience a double login.
With Firefox on Windows I don't believe you even have to check the
"remember passwords" checkbox.
Jess Holle
Ross Jessen wrote:
> Make sure that you have added the Windchill server URL to your trusted
> sites list in your browser, and check the box to remember passwords
> when you log into both Windchill and the applet for the first time. If
> you are using a non-commercial certificate that is not part of
> the standard root certificates chain you will need to import the
> intermediate and root certificate for it into
> <jdk>/jre/lib/security/cacerts on the Windchill server. With this in
> place you should only see the double login the very first time you
> ever open an applet (on that particular client.)
> In Reply to Andrew Miner:
> We just installed windchill 9.1 M010 on solaris 10. I setup ssl as
> per the advanced configuration guide. When I access PDMLink I get
> prompted to logon. What also happens is that when I select a link
> that runs a java applet I get a second prompt for my credentials.
> After that everything runs fine and there are no other logon
> prompts. How do I set up ssl so that I only have to login once?
