I have existing files uploaded in 9.1, but I cannot figure out how to do it in 10.2. I even tried a saveas, but I have no way to edit it or get new content uploaded.
TIA.
In order for the .pcf file to be visible to Creo it has to be uploaded as a CAD document. To do this, you need to add "pcf" to the config.pro option "allow_import_file_extension". Once this file extension is included in this option you can use the workspace import command or directly save the plotter config file directly from Creo to your workspace.
