We mistakenly replaced Creo View Lite with Creo View Express for our PDMLink 10.0 thumbnail viewer. Express is not working properly in this environment. How do we restore Creo View Lite please?
I could be wrong but I don't think there is an option in the Express version.
Just uninstall it then install Creo View Lite from PDMLink. Instructions are from PDMLink 10.1. M050.
Go to Quick Links > Software Downloads.
Select Creo View Installation.
Select the options then the Reinstall button.
Or if you want to download it the install files then pick the link for "Click here to download a complete installer 32-bit or 64-bit.
In the Creo View, Could you set File > Options > Choose edition at startup checkbox
Thank you
Binesh Kumar
Barry Wehmiller
