How do you setup up Oracle RAC in db.properties on PDMlink 9.1 ?
LGrosz
3-Newcomer
Has anyone successfully set up the db.properties settings to recognize an ORACLE RAC database ?
I read that the service_name just needs to be identified and not the wt.pom.jdbc.xxx properties, however, I am not able to get it to work.
Any help would be appreciated.
You need to have three properties set in the db.properties:
  • wt.pom.serviceName=(DESCRIPTION=(ADDRESS=(PROTOCOL=TCP)(HOST=xxx)(PORT=1521))(CONNECT_DATA=(SERVER=DEDICATED)(SERVICE_NAME=xxx))))
  • wt.pom.dbUse=xxx
  • wt.pom.dbPassword=xxx
And remove the jdbc properties:
  • wt.pom.jdbc.hos
  • wt.pom.jdbc.port
  • wt.pom.jdbc.service
