In windchill 11.0 i added the Organization to Administrative user.
I want remove it and come back. I don't find the way.
Organization in the "edit user" must be clear
Hi ,
this is a limitation in windchill principal administration when a user is assigned to an org , there is now way to unassign the org from UI ,you can assign another org , but not unassign the existing one .
you may try the same as in https://www.ptc.com/en/support/article/cs352180 for user ,don't do this on a prod server .
BR,
Fadel
Please refer article https://www.ptc.com/en/support/article/CS333687
It is not possible to delete the organization context.
you can remove the organization from the user.
Thanks!!
Hello, i know.
I want remove the organization from the user (site administrator)
Hi @FC_9723361
There is no way how to do it as a user.
You can just change the organization.
You may change database entry to remove the organization but it can case more problems then you can imagine 😄
PetrH
Hi ,
BR,
Fadel
