How to Analyse publishing job logs for long running job
khimani_mohiki
Version: Windchill 12.1
Use Case: We have some CAD Documents which take a very long time to load in the CADworker, I can see that in the job logs. What I want to do is make a query to a data dump of the job start and end times and the number iof the EPM document, so I can identify objects which take along time to load.
Description:
We have some CAD Documents which take a very long time to load in the CADworker, I can see that in the job logs. What I want to do is make a query to a data dump of the job start and end times and the number iof the EPM document, so I can identify objects which take along time to load. I can see there is a db table for publishing stats, but its only got the job start and end date, not the time, so where are the job logs stored?
Windchill Performance Advisor can bake that data for you and provide XML file. This is your OOTB starting point.
I think you can easily process the XML to get the further data quality you are looking for.
Cheers
Hari
