How to Stop a Complete Task in a workflow based on resulting object state
jsirrell
I am using Windchill PDMLink Release 13.0 and Datecode with CPS 13.0.2.4
Is it possible to check a resulting objects (WTPart) state and if not set to Released stop a Complete Task in a work flow (with message if possible). And only let the Complete Task happen when Resulting object is Released.
Fadel
23-Emerald I
(To:jsirrell)
jsirrell
(To:Fadel)
Thank you I will pass information to my Colleague
You could also use the method described here: https://www.ptc.com/en/support/article/CS115274?source=search
