How to add ACL using API
msingha
3-Visitor
I have a requirement of providing modify access on an IBA of CustomConfigurableMastersLink (subtype of ConfigurableMastersLink).
I tried using AccessControlHelper API but got stuck in the parameters which it takes for creating new ACL.
AccessControlHelper.manager.createAccessControlRule(AdminDomainRef arg0, String arg1, State arg2, WTPrincipalReference arg3, AccessPermissionSet arg4, AccessPermissionSet arg5) throws WTException
Can someone please guide me with the parameters. Or with some alternate solution to give ACL using API.
Appreciate your help.
Thank You.
Manisha
It's not that easy! I needed a long time to figure it out, but I will provide it what I found out.
arg1 = AdminDomainRef adminDomainRef
AdministrativeDomain localAdministrativeDomain = AdministrativeDomainHelper.manager.getDomain(sDomain, localWTContainerRef);
adminDomainRef = (AdminDomainRef) (new ReferenceFactory()).getReference(localAdministrativeDomain);
arg2 = String objectType
arg3 = State lcState
arg4 = WTPrincipalReference wtPrincipalReference
arg5 = boolean false (Set default to false)
arg6 = AccessPermissionSet accessPermissionSetGrant
accessPermissionSetGrant.add(AccessPermission.ALL);
arg7 = AccessPermissionSet accessPermissionSetDeny
accessPermissionSetDeny.add(AccessPermission.ALL);
arg8 = AccessPermissionSet accessPermissionSetAbsolutDeny
accessPermissionSetAbsolutDeny.add(AccessPermission.ALL);
Call
AccessControlHelper.manager.createAccessControlRule(adminDomainRef, objectType, lcState, wtPrincipalReference, false, accessPermissionSetGrant, accessPermissionSetDeny, accessPermissionSetAbsolutDeny);
Hope that will help you
Thanks a lot Bjorn. This really helped !!
Just have one question, what does "sDomain" stands for in getDomain parameter..??
‌sDomain is the domain on the policy manager. This is most of the time /default or could be /default/pdm
