Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
Hi @Gucio
It is not possible by User interface
You need to use loadfromfile utility from Windchill Shell
the help describes how to do so Using Load Files to Update Options and Choices
if you need more how to use load from file utility
check this help
Using the LoadFromFile Utility
PetrH
PetrH,
it used to be written in ptc university's documentation
Hi PetrH,
yes, the same option set has been assigned.
Hi @Gucio
This wizard is used to define only part attributes, not assigning the options. Based on the help I may be wrong 😄
Or preference has to exist that allow you to edit the options in this wizard.
It can also be connected with correct license group that allows you to do it in the edit multiple parts wizard
Check the profile setting if there can be allowed this function or try to search in preference options.
In my case I can use assign expression from structure to set the option.
PetrH
PetrH,
you are right - this is the way how to assign choice to ONE part
If you select more parts - assign is not possible
But it is written that possibility of assigning choice for several parts in one action should be available
The document was created for Windchill 11.1 - should I treat this possibility as missed in 12.1??
Hi @Gucio
What license group is your user assigned?
There can be some license restrictions on that in the Multiple Edit Wizard
PetrH
Hi PetrH,
user is added to PTC Smart Platforms License (Site) group.
Hi , just check that wizard , such action don't exit OOTB in the edit multiple Wizard :
For bulk assigning expression, the only way is to use LoadFromFile , see https://support.ptc.com/help/wnc/r12.1.1.0/en/index.html#page/Windchill_Help_Center/WCDataLoadGuide/WCDataLoad_OptionsLoadFilesToUpdateOptionsAndChoices.html
Hello Petr,
glad to hear from you again , I think this info is from the PTC University, the Windchill Help Center has no such info :
I'm not sure how to correct the PTC U documentation , for the Windchill Help Center we open Documentation's SPRs to R&D .
Hi @Fadel
Oh I worked with the word "documentation" that I thought it is help page, ok it is really University Curse documentation. You know I can't read carefully 😄
PetrH
Hi Gucio,
This is Charles from PTC Technical Support in Europe.
Was the information provided helpful somehow?
KR,
Charles.
HI Charles,
to be honest - I still don't know how to assign choice for several parts in one action. So question is still open.
Hi @Gucio
check this help
PetrH
HI PetrH,
It is not the best answer that I expected, but many thanks for your time.
