How to avoid publishing for a particular context (Product in our case)
RajeshBalasunda
2-Explorer
We are on Windchill 10 M040. We are currently mass loading CAD Files (.SLDPRT) into a particular context. We do not want to publish these files for now. These files follow the same LC as any other EPM Document. Is there a way to prevent publishing only for this context, as it puts a huge backlog on the WVS jobs.
Rajesh Balasundaram
Rajesh,
You can write custom filter method to check if document is for particulate context. see below links for more details.
http://www.ptc.com/cs/help/windchill_hc/wc100_hc/index.jspx?id=WCCG_BusLogicCust_WCVisualization_CustPublish&action=show
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS98475&posno=1&q=publish%20filter&source=search
Hope it helps !!!
Shreyas
