How to change from Site to Organizational level in Windchill
Amirtharaj_K
Hi Guys,
I created a one-doc-type misunderstanding on the site, how we can change to an organizational level.
Aj
Hi @Amirtharaj_K,
Thank you for your question
I’d like to recommend to bring more details and context to your initial inquiry.
  • Version Information: Which version of Windchill are you using? Different versions might have different procedures or limitations.
  • Documentation: Have you referred to any specific documentation or guides while trying to make this change? If so, which ones?
  • Error Messages: Are you encountering any error messages or issues when attempting to change to the organizational level?
  • Permissions and Roles: Do you have the necessary permissions and roles to make this change?
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Vivek N
Community Moderation Team.
Fadel
23-Emerald I
(To:vnamboodheri)
refer to Article - CS161191 - How to move soft-types and global attributes from Site level to an Org level in Windchill ,  if you have data cerated at that type , you have to create ab equivalent on org level and then use the type move tool  https://www.ptc.com/en/support/article/cs368420
Fede
HelesicPetr
(To:Fadel)
@Fadel is right
It could work. Create new subtype with new unique internal name
Use the utility to change the object type on the existing documents
Remove the old type.
Rename the new type to the original one you want.
PetrH
Hi @Amirtharaj_K
Do you talk about a type and attribute management?
Unfortunately only deleting the subtype solves your situation and create it on the right organization
I do not know any existing method for moving the subtype from a site to an organization.
PetrH
