How to change the meeting minutes character limit
DimitriVanWijk
Hello, We are using the minutes linked to the meetings, but we need our minutes to accept more than 4000 characters. Does anyone know if it is possible to change this meeting minutes character limit ? And if the answer is "yes", how to proceed ? (Can we change it directly in the wt.meeting.MeetingCenterMeetingInfo object (UpperLimit=4000)?) Thanks a lot in advance.
4000 is the maximum for an nvarchar data type. Anything more then that would require a BLOB so I'm afraid you are out of luck.
Hi Patrick, Thanks a lot for your answer. I will try another way to handle my problem. Thanks again.
