How to combine windchill list
OnurNalbantoglu
How can I combine the lists in the package?
HelesicPetr
(To:HelesicPetr)
Hi @OnurNalbantoglu
Try to do so from context / product / library team
There you can change the profile setting based on the roles of the context.
Can not find any better way now.
PetrH
10 REPLIES 10
Hi @OnurNalbantoglu
What do you mean combine? Try to explain what you need.
PetrH
I want to show users only the folders element from the lists under the package
@OnurNalbantoglu
Try to use Profiles.
Create own profile and add users to it
Set the visibility of product list to not show what you need to user.
You need to find all functions to hide them.
I guess that almost all you can hide to the users
PetrH
I did what you said but it didn't work
@OnurNalbantoglu
 If you use license profiles then my idea can not work because you can not edit the license profiles and they always shows the links under a product/library
License profiles are attached to the license groups.
For example Windchill Base license shows the links under a product/library and admin can not change it what I know.
Another way is to remove the links from customActiomModel.xml but if is bad idea to do so.
You remove it for all users also admins.
PetrH
HelesicPetr
(To:HelesicPetr)
Hi @OnurNalbantoglu
PetrH
I did what you said and it worked. thank you.
Is it possible to remove links from customActiomModel.xml for a single library
No. Check my previous reply.
PetrH
Thank you:)
