How to create Managed Variant Specification?
HR_10750679
Hello People,
I want to explore Modules option in Variant Specification. Could anybody tell me how to create a Managed Variant Specification, as I could not see the Modules tab in a normal Variant Specification.? Looking forward to your response.
Thanks in advance.
Sha
Fadel
23-Emerald I
(To:HR_10750679)
Here we go :
in the Prod Family  , you can insert a Product Model either directly under the PF or in a product Model group (optional) , The VS is then created under a product model using insert new
There is a another type of VS , that can be created directly from PSB ,see https://www.ptc.com/en/support/article/CS386716
Fede
6 REPLIES 6
HelesicPetr
(To:HR_10750679)
Hi @HR_10750679
You need good option and variant definition.
The WTPart needs to be set as a configuration module
A Option set needs to be assigned to the WTPart
Then you can find configuration button in the action menu
This button opens the configuration Wizard
PetrH
Hello @HelesicPetr ,
Thank you for your response. I had already tried the way you provided, but it was creating standard Variant Specification where I do not see the Modules tab in the Structure tab. Since I want to explore the capability of Modules tab, I want to create a Variant Spec which would have that tab,
HelesicPetr
(To:HR_10750679)
Hi @HR_10750679
First you need to create s product family as a child of a product model.
Managing Variant Specifications in a Product Family
PetrH
@HelesicPetr ,
I created Product Family and Product Model, but I do not see an option to create a Variant Spec from either of them. Could you tell me how a variant spec can be created from a Product Family?
Thanks.
Fadel
23-Emerald I
(To:HR_10750679)
Here we go :
Fede
@HelesicPetr , @Fadel ,
Thank you, I successfully created Managed VS and made use of Modules Tab to create a variant. Could you tell me when the users go for manual selection instead of assigned expressions?. I get if the options are not pre-loaded in the system, users has to go for manual selection. But when would manual selection preferred to defining the options and choices?. When done manually, does not that make it prone to mistake or error?
Thanks.
