How to create an info engine task to get change notices which are having WTPart as changeable(Both Affected and Resulting)?
If anyone can provide the solution would be thankful.
Are you simply looking for the webject, that can query change notice object? Or you want to do it based on certain condition? Could you please elaborate your problem statement little bit.
Lokesh,
Were you able to figure out how to create the task? If so, could you please share your solution for the benefit of the community?
