Can anyone help to create windchill product through API. thanks in advance
Hi @nimish ,
Did you try using below example?
<%@page language="java"%> <%@taglib uri="http://www.ptc.com/infoengine/taglib/core" prefix="ie"%> <ie:webject name="Get-Properties" type="MGT"> <ie:param name="ATTRIBUTE" data="wt.federation.ie.VMName"/> <ie:param name="GROUP_OUT" data="properties"/> </ie:webject> <ie:webject name="Query-Objects" type="OBJ"> <ie:param name="INSTANCE" data="$(properties[0]wt.federation.ie.VMName[0])" /> <ie:param name="TYPE" data="wt.inf.container.WTContainer"/> <ie:param name="ATTRIBUTE" data="name" /> <ie:param name="WHERE" data="name='Demo Organization'" /> <ie:param name="GROUP_OUT" data="container" /> </ie:webject> <ie:webject name="Query-Objects" type="OBJ"> <ie:param name="instance" data="${properties[]wt.federation.ie.VMName[]}"/> <ie:param name="attribute" data="*"/> <ie:param name="type" data="wt.inf.template.DefaultWTContainerTemplate"/> <ie:param name="where" data="name='${@FORM[]template[]}'" default="General Product"/> <ie:param name="group_out" data="template"/> </ie:webject> <ie:webject name="Create-Objects" type="ACT"> <ie:param name="INSTANCE" data="$(properties[0]wt.federation.ie.VMName[0])" /> <ie:param name="CONTAINER_REF" data="$(container[]obid[])"/> <ie:param name="FIELD" data="containerInfoName='Product Test4'"/> <ie:param name="field" data="containerInfoNumber='Product Test4'"/> <ie:param name="field" data="template=${template[]masterReference[]}"/> <ie:param name="FIELD" data="privateAccess=false"/> <ie:param name="TYPE" data="wt.pdmlink.PDMLinkProduct"/> <ie:param name="ATTRIBUTE" data="name, obid" delim=","/> <ie:param name="GROUP_OUT" data="$(@FORM[]group_out[])" default="product" /> </ie:webject>
Note: Modify highlighted fields accordingly.
Best Regards,
Shirish
Thanks Shirish for the reply I will try it.
