Hi Developers,
Unable to remove EpmDocuments from windchill, please check below exceptions and provide code snippets to delete epm documents :
- INFO : wt.system.err wcadmin - (wt.fc.fcResource/46) wt.fc.ReferentialIntegrityException: Referential integrity violations occurred for this operation:
- INFO : wt.system.err wcadmin - The following items cannot be deleted because they are members of "EPMCheckpoint - wt.epm.workspaces.EPMCheckpoint:1266915". "Assembly - 0000000501.asm, A.1 (1); "
- INFO : wt.system.err wcadmin - The following items cannot be deleted because they are members of "EPMAs Stored Config - ". "Assembly - 0000000501.asm, A.1 (1); "
Thanks.
Hi @mohitenw
Article https://www.ptc.com/en/support/article/CS44609 is good to know about steps necessary to delete or purge EPM Documents or CAD Documents.
Pshinde
Hi @mohitenw
Pshinde
