We are currently experiencing a service disruption impacting community and support login. Our teams are working to resolve the issue.
Hi
How to delete product from windchill not folder inside the product ?
By mistake I created product then later I understood there is not delete option
But I want to delete .
A product once created can not be deleted, only renamed. If the possibility exists that you will need a new product in the future, mark it read-only for now and rename it when you do need the new product.
Thank you so much
I got it
What about folder ? The same will aplly ?
I think an empty folder may be deleted. It has been a while since I have tried it and I'm not at a system to test.
Once again thanks for your immediate reply.
Do u have any idea that how to export config.pro , symbol files, material files, dtl files into windchill ?
You do not want those files in Windchill. Only your start part template files get a copy installed in Windchill as that prevents the system from loading them to your workspace and marking them as new.
Yes, a regular folder that is contained within a Product folder can be deleted.
I know this is old, but I would also like to add that the recommended method to modify a product template is to create a new product from an existing template, make the modifications required, do a save as template and then delete the original template. This leaves you with a floating product, that you cannot delete. SO in my humble opinion it is not a very effective way of modifying a product template, but it is nonetheless, the only way I can think of.
This is the article about modifying a product template
https://www.ptc.com/en/support/article?n=CS20918&source=snippet
