HI
I have an assembly which has more than 100 parts. Almost 20 out of 100 parts are constrained using one particular part as a reference . And the same part I don't want to upload into windchill ?
If it not possible as per windchill methodology , I don't want to create wt part for the the particular part after uploaded into windchill . Also I want to create wt part for the remaining parts except that reference part.
Because we used that particular part only for reference to other part to be assembled .
Ex:
Engine.asm
A.prt
B.prt
Z.part
The above mentioned "B" part as a reference part , based on that the part number e,f & many part will get assembled . At present I am hiding "B" part in assembly model tree .
