The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
How to get BaselinedPlan object
adev-2
I am trying to retrieve BaselinedPlan object using the OOTB api but when I try to get object it throws me class case exception. can any one tell me which API i can use to retrieve BaselinedPlan
code using:
PlanActivity pa = getPlanActivity(activityName, proj);  // get PlanActivity
  ObjectReference objRef = wt.fc.ObjectReference.newObjectReference(pa);
  com.ptc.projectmanagement.plan.baseline.BaselineHelper.service.getActiveBaseline(objRef);
Error Message : Caused by: java.lang.ClassCastException: com.ptc.projectmanagement.plan.baseline.BaselinedPlanActivity cannot be cast to com.ptc.projectmanagement.plan.baseline.BaselinedPlan
BhushanNehe
(To:adev-2)
You are querying BaselinedPlanActivity, you can get the BaselinedPlan object from BaselinedPlanActivity using the below API
<<BaselinedPlanActivity-Object>>.getRootReference().getObject();
Bhushan
adev-2
(To:BhushanNehe)
Hi Bhushan,
thank you for your replay I have also found an api to retrieve Baseline object
BaselinedPlan bp =  com.ptc.projectmanagement.plan.baseline.BaselineHelper.service.getActiveBaseline((ObjectReference.newObjectReference(plan)));
