I want to get all attribute Internal name which are related to WTPart or WTDocument
Hi @RS_10128209
the API does not exists or I don't know it.
You need to write code to find TypeDefinition and then get attribute list.
Here is a code for you that can work. Just define soft type internal name and it returns what you need.
For me it works
try
String typeName = "wt.epm.EPMDocument";
QuerySpec queryspec;
queryspec = new QuerySpec();
int idLWCObject = queryspec.appendClassList(LWCTypeDefinition.class, true);
CompositeWhereExpression andCondition = new CompositeWhereExpression(LogicalOperator.AND);
andCondition.append(new SearchCondition(LWCTypeDefinition.class, LWCTypeDefinition.NAME, SearchCondition.LIKE, typeName), new int[]{idLWCObject});
queryspec.appendWhere(andCondition, new int[]{idLWCObject, idLWCObject});
queryspec.appendOrderBy(new OrderBy(new ClassAttribute(LWCTypeDefinition.class, LWCTypeDefinition.MODIFY_TIMESTAMP), false), new int[]{0});
QueryResult qrTypeDef = PersistenceHelper.manager.find((StatementSpec) queryspec);
if (qrTypeDef.hasMoreElements())
while (qrTypeDef.hasMoreElements())
Persistable persistables[] = (Persistable[]) qrTypeDef.nextElement();
if (persistables.length > 0)
LWCTypeDefinition lwcObj = (LWCTypeDefinition) persistables[0];
ArrayList typeList = LWCCommands.getTypeAttributes("OR:" + lwcObj.toString());
for (Object typeAtribs : typeList)
if (typeAtribs instanceof AttributeDefinitionReadView)
System.out.println(((AttributeDefinitionReadView)typeAtribs).getName());
} else
System.out.println("nothing");
} catch (Exception e)
// TODO: handle exception
e.printStackTrace();
PetrH
Hello @RS_10128209
Go to the Type and Attribute Management and check all subtypes what you want.
There you can see all internal names.
PetrH
