Version: Windchill 12.1
Use Case: While creation document, I wanted to implement validation for user to get popup confirmation based on some attribute value. ( if attribute value is "XX", confirm if you want to proceed further or cancel)
Description:
I gone through the PTC documentation and found below information, which is not sufficient to implement UIValidationStatus.PROMPT_FOR_CONFIRMATION as a beginner :
I have already wrote a logic and status also getting set (as per printing "result" in MS) for this, but just need to set the further steps to handle the confirmation popup.
Thank you
Hi LB_10619520
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Community Moderation Team.
Hi, I have not used UIValidationStatus.PROMPT_FOR_CONFIRMATION previously but as per your use case, I think the same can be achieved through adding the code logic under .jsfrag file and it gets invoked on complete
eg: https://www.ptc.com/en/support/article/CS35488
Hello @WT_010219,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
