How to hide attributes from Search Criteria and Table Views?
ShreyaPatil
2-Explorer
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.2.10
Table views should be the easy one, create a custom table view. For search criteria, probably will be some customization unless you want to hide the attributes anywhere in the system for a specific group of people...
If that is the case, you can use a profile and select which attributes you want to hide for those people....
If the need is the ability to define technical or internal attributes not exposed nor usable by End Users,   it could be a nice idea for PTC to have this option also in the Type Manager .
Some other PLM platform allow to define this in their low-code data model  module
If it is a group of end users with a specific set of attributes across the entire system, I would use the profile method I suggested above.  I would create a group that encompasses all non-admin users and use the group in the profile
Hello ShreyaPatil,
I'm Charles from PTC Technical Support in Europe: Was the information provided helpful somehow? Or may I suggest you open a new case for this question?
KR,
Charles.
