How to integrate CAS unified authentication in windchill12.0?
林唐_10981168
Version: Windchill 12.0
Use Case: How to integrate CAS unified authentication in windchill12.0? What configurations need to be modified?
Description:
The people in this community would not know what you are trying to do. I suggest that you
  • Say what you are trying to do (details pls, and screenshots and links). What have you done so far to integrate CAS? How many systems are using the CAS unified authentication?
  • What did you expect to see
  • What did you actually see
Here is the help page for it (not so helpful, right?):
https://support.ptc.com/help/identity_and_access_management/en/index.html#page/iam/AzureADasCASandIdP_Windchill.html#
But as I understand it, this is only needed when you are using Thingworx (corrections please!). So if you are using Thingworx you might be better off looking at the Thingworx forum.
https://community.ptc.com/t5/ThingWorx-Navigate/bd-p/thingworxnavigate
林唐_10981168
(To:rleir)
This way doesn't work,I'm stuck now, verifying this step. I don't know how to configure the callback address. I've already got the token.
Hi @林唐_10981168
Thanks for using PTC Community,
I wanted to let you know that there are some questions to you on your topic.
If you are in a position to respond to this question, that would be great.
Vivek N
Community Moderation Team.
林唐_10981168
(To:rleir)
I've solved it, thank you
