I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.2
I want to listen on an WTPart action for "Actions-> Edit Common attributes". I am able to listen to event "PersistenceManagerEvent.UPDATE" and object type WTPartMaster. But i am facing the issue that this event triggers on every CAD check-in.
I am not able to differentiate the event on action and check-in. Is there any way to difference the event ?
Was able to achieve from the workaround of find the modified date of the object.
To be sure to get the right event, you could overwrite the forms processor class.
com.ptc.windchill.enterprise.part.forms.EditPartCommonAttrsFormProcessor
Hi @syalagudri ,
In the Listener class please add the condition to check whether it is a WTPartMaster object type or not.
if(obj instanceof WTPartMaster){
Added. But on check-in also i get the same object type so not able to differentiate.
Hello syalagudri,
I'm Charles from PTC Technical Support in Europe, I will provide you assistance on this question.
Can you review kb article CS147573 and let me know how it could help?
KR,
Charles.
Hello syalagudri,
Thanks for your feedback, and congrats to you for figuring out the solution.
Are there any details you can share how it got resolved?
I will be grateful if you can send me this information.
KR,
Charles.
