How to maintain simplified representation in windchill ?
In the assembly I have more than 10 representation , each consider as an base level assembly for next level assembly .
But out of 10 rep (i.e Assm) , we have freezed one rep. That I want to upload into windchill & it have many common parts which will be using for other rep.
Is it possible to open the freezed assem (rep) individually from windchill ? if I upload individual parts from freezed rep & skip the remaining rep parts .
If i understand your question correctly, you are now working with Internal Simp. Reps? you should probably be looking into External Simp. Rep's
Yes.Got the solution.
Have 6 representation in master assembly and created drawing for each rep by activating view states option inside drawing and assign the drawing number for each rep .
How wt part number will be created and link for different simplified rep drawing?
