How to open two Creo at the same time, each Creo uses a different workspace, what settings?
WY_4528322
3-Newcomer
I am using Windchill PDS - Internal Site Release N/A and Datecode with CPS N/A
How to open two Creo at the same time, each Creo uses a different workspace, what settings are required?
Translated by the Community Moderation using Google Translate
如何同时开二个Creo,每个Creo用不同的workspace,需要做什么设置?
HelesicPetr
(To:WY_4528322)
Hi @WY_4528322
You can create two separate cmd(bat) creo start file where you define a cache for the creo session
or you can define more parametric.psf files where you can set the properties for creo cache
First cmd file Creo10.cmd
ENV=PTC_WF_CACHE=c:\Cache10\Creo_10.0
ENV=PTC_WF_ROOT=c:\Cache10\Creo_10.0
"C:\PTC\Creo 10.0.0.0\Parametric\bin\parametric.exe" "C:\PTC\Creo 10.0.0.0\Parametric\bin\parametric.psf" %*
Second cmd file Creo9.cmd
ENV=PTC_WF_CACHE=c:\Cache9\Creo_9.0
ENV=PTC_WF_ROOT=c:\Cache9\Creo_9.0
"C:\PTC\Creo 9.0.3.0\Parametric\bin\parametric.exe" "C:\PTC\Creo 9.0.3.0\Parametric\bin\parametric.psf" %*
Hope this can help
PetrH
