How to persist multi value IBA using event listener (Create and Update)
Highlighted
How to persist multi value IBA using event listener (Create and Update of object)
Tags (1)
Highlighted
Re: How to persist multi value IBA using event listener (Create and Update)
You can listen for VersionControlServiceEvent.NEW_VERSION or VersionControlServiceEvent.NEW_ITERATION. See below article to update the attributes using Listener .
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS99191&art_lang=en&posno=5&q=listener%20cr...
Also, You can set below verbosity  to true in wt.properties to check event keys  for create or update
wt.services.verbose
wt.services.verboseEvents
Hope it helps !!!
Shreyas
