How to put a copy of the Primary Business Object in server folder?
mdigman-2
Does anyone have a recommendation on the best way to put a copy of the PBO from a workflow into a local folder on the server? We have Excel files that are being saved and routed in PDMLink (10.0), and at a certain point in the approval process we want to do some outside processing with the file. Basically, the file would be placed into a folder on an FTP server, and then an ERP system would be updated with the location of the file. This is all easy to do, except I don't know the best way to get a copy of the file into a local folder on the server.
If someone could point me in the right direction I would appreciate it.
Micah
I found most of what I need in this post (which was running about the same time as my question).
http://communities.ptc.com/message/209699#209699
