I have mapped some mass properties of Solidworks to Windchill 11.0 M020, but the values displayed are upto 13 decimal points.
Is it possible to reduce the value to get only upto two decimal points. If yes, please suggest
Thanks & Regards,
Irfan
Irfan,
You can file product Idea.
Irfan,
Thanks Harshal for your response
Hi Harshal,
Is it the same with the attributes of type "Real number with units"?
Yes
See CS355753
Basically create 3 attributes and use them as calculation for 3 decimals (Or whatever number of decimals you want)
