Is there any way to maintain the relation between two wtparts other than usagelink ? like reference relation between wtparts?
Replacement Parts - Use Alternates
Thanks, But is there any possibility to maintain any reference relation between the two parts?
Why we want this is, we have some Part/BOM variants with different numbers, So we wanted to show them as referenced by each other, or with the master Part/BOM. Please suggest if there is any better way to handle this ?
You could implement a configurable link. See also Configurable link
Starting witch WC12.0 you also can configure the selector to collect the parts with a configurable link.
Unfortunately to setup that, a little customizing is still required.
We haven't used this functionality, but you might consider linking the WTParts as Alternates.
