How to resize the table in Windchill 10.1 to show all the objects?
SelvamP1
7-Bedrock
We have a table which is showing the WTPart objects (100 Parts are in the table). The table is showing only 10 objects and we need to scroll down the table to see the full list of objects.
But the requirement is it should display all the objects in the table. How to achieve this requirement?
Selva
Is the Window to small to show all rows? Then you can catch the bottom borderline and drag it down to show more lines.
If you only can see 10 rows in a Table, it is a Preference, that manage this.
(Preferences, Table, Size Limit)
Have a great day
Thomas
No the window larger enough to fit the table. It is a custom table. I want to fix the code. it should automatically fit the table rows. I dont want to the user to drag and see.
Preference set to 2000;
I use the below code:
<jca:describeTable var="tableDescriptor" id="cnreport.affected.revisions" configurable="false"
label="Resulting Objects - Parts">
<jca:describeColumn id="type_icon" sortable="true" defaultSecondarySort="true"/>
<jca:describeColumn id="number" sortable="true" defaultSort="true" />
<jca:describeColumn id="name" sortable="true" />
<jca:describeColumn id="version" sortable="true"/>
<jca:describeColumn id="source" sortable="true"/>
</jca:describeTable>
<c:set var="name2" value="<%=name2%>"/>
<c:set var="number" value="<%=number%>"/>
<jca:getModel var="tableModel" descriptor="${tableDescriptor}"
serviceName="ext.ddd.change.reports.CNRevChanges"
methodName="getResultedObjectsWTParts" >
<jca:addServiceArgument value="${name2}" type="java.lang.String"/>
<jca:addServiceArgument value="${number}" type="java.lang.String"/>
</jca:getModel>
<jca:renderTable model="${tableModel}"/>
Selvam,
Where have you put the below code? In which file?
Ravin K Kayasth
ptc-1160051
(To:SelvamP1)
Trying to revive this.  I have 50 items in my affected objects.  The table defaults to only show some of the items, then I have to grab the bottom of the table and drag down to show more.  This is time consuming to have to do this with 50 to 100 items in my list.  Is there a way to make this table automatically the size of the full list?  I see a response here, but I am new to customization and would not have any idea where to use the code shared here.
