We are happy to announce the new Windchill Customization board! Learn more.
How to set primary classification attribute while creating part
jselvaraj
Hi All,
I am trying to create  a WTPart from java. In my set up the classification is set as a mandatory attribute.
Could you please help me on how to set  the value of the primary classification? I tried to set the default value for the classfication, however it does not work. Here is the code I am using to create WTPart.
   WTPart wtpart=WTPart.newWTPart();
   try {
    TypeIdentifier typeidentifier = TypeHelper.getTypeIdentifier("WCTYPE|wt.part.WTPart");
    WCTypeIdentifier wctypeidentifier = (WCTypeIdentifier) typeidentifier;
    TypeDefinitionReference typeDefinitionReference = TypedUtilityServiceHelper.service.getTypeDefinitionReference(wctypeidentifier.getTypename());
    wtpart.setTypeDefinitionReference(typeDefinitionReference);
    wtpart.setName("Test part007");
    String container_path = "/wt.inf.container.OrgContainer=yyyy/wt.pdmlink.PDMLinkProduct=xxxx";
    WTContainerRef containerRef = WTContainerHelper.service .getByPath(container_path);
    wtpart.setContainerReference(containerRef);
    String folder_path = "/Default";
    Folder folder = FolderHelper.service .getFolder(folder_path,containerRef);
    FolderHelper. assignLocation(wtpart, folder);
    wtpart=(WTPart) wt.fc.PersistenceHelper.manager .store(wtpart);
Thanks in advance.
Hi @jselvaraj,
Have you tried "How to set classification node or classification attributes value (available for 10.2 M030 and 11.0)" section of KB article CS217792?
WTPart part_work = (WTPart)WorkInProgressHelper.service.checkout(part, WorkInProgressHelper.service.getCheckoutFolder(), null).getWorkingCopy();
PersistableAdapter obj = new PersistableAdapter(part_work,null,SessionHelper.getLocale(), new UpdateOperationIdentifier());
obj.load(bindingAttributeName);
obj.set(bindingAttributeName,classificationNode);
obj.apply();
PersistenceHelper.manager.modify(part_work);
return (WTPart)WorkInProgressHelper.service.checkin(part_work, null);
Are you having some trouble doing it?
Shirish
schen-7
(To:ShirishMorkhade)
I agree to use PersistableAdapter class to set the classification attribute value.
Lokeshwaran_S
(To:jselvaraj)
Hi selvaraj,
could you please provide me a import statement for  TypeHelper.getTypeIdentifier();
It would me more helpful for me.
