How to set the number to folders?
lnessi
I can't set the number to folders in common space!
Anand
(To:lnessi)
Hello Luca,
You cannot set a number to a folder, it would be a blank always, however when you create a WT part/ EPM document or any other Windchill objects inside the folder this column will be filled.
You can do that test, please create few documents inside the document folder you will get to know the difference
Athmanand
6 REPLIES 6
STEVEG
(To:lnessi)
Can you provide more details?
Anand
(To:STEVEG)
Hello Luca,
Can you explain more about this ?
Is it possible to share few snapshots ?
Athmanand
lnessi
(To:lnessi)
Hello
I apologise for the delay!!!
Here a picture to explain better, i need to fill the column number for every folder, where the red circle indicates.
Thanks.
STEVEG
(To:lnessi)
I could be wrong but I don't think that's possible.
BenLoosli
(To:lnessi)
The Number column is always blank for a folder.
Why do you need a number for a folder?
What purpose does a number do for your folders?
Anand
(To:lnessi)
Hello Luca,
Athmanand
