I recently updated our windchill 11.0 CPS and the customization we had to the find number field got dropped.
I'm stuck on step 2D of the help file linked below. Can anyone tell me what syntax I use in the xconfmanager?
You can try with this command:
xconfmanager -s "wt.services/svc/default/wt.part.ValidateFindNumbersDelegate/null/java.lang.Object/0=wt.part.DefaultValidateFindNumbersDelegate/duplicate" -t "codebase/service.properties" -p
Regards
![]() | Iker Mendiola - Prambanan IT Services |
Regards
Thanks! That's exactly what I needed.
