How to use SetState for Promotion Request Objects using Expression Robot of workflow?
maheshkumar
Hi Gurus,
I am using Windchill 11.0 M010, The selected Promotion Request Targets/Objects should move to a Life Cycle Stateusing API,
following APIs tried use,
QueryResult qr = wt.maturity.MaturityHelper.service.getBaselineItems((PromotionNotice pn);
2.       Set state for the Promotion Notice objects:
wt.lifecycle.LifeCycleServerHelper.service.setState(LifeCycleManaged object, State state);
I have the code however i am unable to compile , setState is not recognizing.
Please help me
Thanks & best regards,
Mahesh
First line has non matching brackets
Coming back to your question:
Modify your code as follows:
java.lang.Object obj;
  wt.lifecycle.State state;
  wt.lifecycle.LifeCycleServerHelper.service.setState((LifeCycleManaged) obj, state);
Hi Rajesh,
Thanks for the reply,
I have validated the same following errors coming,
Checking Syntax...
C:\ptc\Windchill_10.2\Windchill\temp\WfExpression_Administrator.java:41: error: package javalang does not exist
javalang.Object obj;
C:\ptc\Windchill_10.2\Windchill\temp\WfExpression_Administrator.java:43: error: cannot find symbol
  symbol:   class LifeCycleManaged
Note: C:\ptc\Windchill_10.2\Windchill\temp\WfExpression_Administrator.java uses unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
2 errors
Syntax check complete.
Your first error in this line is due to a missing "." in the package declaration. You have:
this needs to be:
The second error is due to an incomplete package declaration for the LifeCycleManaged class. You have:
this needs to be:
wt.lifecycle.LifeCycleServerHelper.service.setState((wt.lifecycle.LifeCycleManaged) obj, state);
Hi Zach Sternal,
Thanks for the observations,
I am getting the following error, i would feel that i am unable to define a Proper obj variable. I am new to customization.
Can you please help me out.
Checking Syntax...
C:\ptc\Windchill_10.2\Windchill\temp\WfExpression156153.java:45: error: variable obj might not have been initialized
C:\ptc\Windchill_10.2\Windchill\temp\WfExpression156153.java:45: error: variable state might not have been initialized
Note: C:\ptc\Windchill_10.2\Windchill\temp\WfExpression156153.java uses unchecked or unsafe operations.
2 errors
Thanks in Advance
Best Regards,
Mahesh
