I have datasheets and request emails to attach to parts, hundreds at a time.
I don't want to use the commandline (NMLoader) method, although i have in the past, one reason is that it leaves no traces (iterations).
Is there a way to use ImportSheetType=Document, can I see an example please?
I have been creating parts using Import From Spreadsheet, that works well most of the time.
Hans Schulze
I am surprised that online help doesn't mention this function much. Was there a manual or guide written for it?
Hans Schulze - today only loading Part, BOM, AVL/AML and Replacements are supported in the Excel Import/Export framework.
There is a partner Wincom Consulting that does have an Excel based loader for Documents.
Can I put a document in a BOM format upload?
The Excel Import/Export will only operate on WTPart objects today. This would not work
I have created a tool to generate an NMLoader XML file from VBA.
ftp://ftp.sonic.net/pub/users/bubblecdn/Create_Document_Upload_XML.xlsm
This spreadsheet assumes that you have 0 or 1 Describe-By document, and 0-2 Reference-By documents to upload. If you need a different configuration, you need to put on your VBA hat, and edit the code. Note that cell labels are used extensively.
Hans,
Pretty slick spreadsheet, this streamlines the process quite a bit. Thanks for sharing.
I found a bug when updating some parts, that I had to include the MfrName despite that the part numbers were unique to each Mfr. Just provide the Mfr name or leave it blank.
ftp://ftp.sonic.net/pub/users/bubblecdn/Create_Document_Upload_XML_Mfr.xlsm
Very nice tool.
Thank you very much for making it available.
Much Appreciated
Scott
