We connected thingworx and windchill. While upgrading Windchill, we not able to run thingworx server. If we need to use thingworx server when windchill server is under upgradation, how to do it ??
I think I am in the same boat. If we are talking CPS update, you should be able to run ThingWorx when Windchill CPS is finished applying. I think you are referring more to a version change, right? I am running the standard upgrade to a new target system off to the side so production should remain operational until my final upgrade date. My assumption has been that ThingWorx needs the same approach, to install a new version of Thingworx on a new target linked to my new target. Our custom apps will be copied over along with user accounts and groups. Worse case, we might have to re-enter users and groups again. Does this describe your situation?
