I am wondering how I can see the values I created in the creo parameter table in windchill.
Do you have an article or training video on this???
Hi @Inho-_-
Following article describes how to do so
CS23615 - How to map a Creo Parametric parameter to a Windchill attribute
general steps:
1. Set the parameter as Designated in the Creo Parametric
2. Create a Windchill Parameter as a global parameter with correcct type in the Type and attribute management
3. Add the global parameter to a CAD Document type.
Now the Upload operation moves the value from Creo to Windchill.
PetrH
Hi @Inho-_-
general steps:
PetrH
In addition, you will need to modify the detail information screen in Windchill to display the attributes uploaded from the Creo parameters.
Hi @BenLoosli
Usually, the attributes added to a soft type are automatically part of a detail page layout.
Yes you can reanarange the layout to bettrer look.
PetrH
True, however they are not always organized in a way that looks good
With the help of your article, I was able to map the parameters entered in Creo to Windchill CAD Part Attribute items.
Thank you very much
Additionally, the modeling Mass Properties information in Creo cannot be Designate Checked, is there any way to map the following values to Windchill???
Hi @Inho-_-
The attributes are analytics output so I don't have experience with that attribute type, and it seams that you would need to create some relations in the model to fill normal attribute with analytics values. and set this attribute as a designated.
PetrH
We use a relation in our start files for weight = pro_mp_mass. Then we designate the weight parameter to Windchill.
