HyperLink back to Information Page in Windchill 10.0M020
BrianSullivan
Hello:
I thought we had a solution but we do not... IT never tested after my initial Attempt.... ERP Connector XML Output Has Different Object ID then Link Shown when you go to the Information Page.. We Tried Replacing XML Output OID into Place in Weblink but this does not work.
Anyone Built the Link to Show in their MRP System using the ERP Connector XML Output?
<bomheader>
<objectid>OR:wt.part.WTPart:15659029:876255306-1318897741269-1024870177-96-10-168-192@hawca1.acme.com</objectid>
<class>com.ptc.windchill.esi.BOMHeader</class>
<lastchangedby>orgadmin</lastchangedby>
<number>1000000005</number>
<starteffectivity></starteffectivity>
The Information Page:
">http://hawca1.acme.com/Windchill/app/#ptc1/tcomp/infoPage?oid=VR%3Awt.part.WTPart%3A15659011&u8=1<http: hawca1.hoshinet.com=" windchill=" app=" #ptc1=" tcomp=" infopage?oid="VR%3Awt.part.WTPart%3A15659011&amp;u8=1">
In 9.1 A colleague Showed me that you could pull the ID and Replace in the Visualization link... I thought I had gotten it to work for Info Page... but I was mistaken... Also the New Link to PV Lite (Calls for an actually Number.pvs.. in it so a generic link may not work)Anymore as well
Since then we have decided we really would like the Link to the Information Page in the MRP System...
Brian Sullivan
XML Output related to PART
<part>
<class>com.ptc.windchill.esi.Part</class>
<endeffectivity></endeffectivity>
<startserialnumbereffectivity></startserialnumbereffectivity>
<endserialnumbereffectivity></endserialnumbereffectivity>
<startlotnumbereffectivity></startlotnumbereffectivity>
<endlotnumbereffectivity></endlotnumbereffectivity>
<serialnumbereffectivitycxtpartnumber></serialnumbereffectivitycxtpartnumber>
<lotnumbereffectivitycxtpartnumber></lotnumbereffectivitycxtpartnumber>
<defaultunit>ea</defaultunit>
<name>XML TEST</name>
<parttype>separable</parttype>
<source>make</source>
<state>DESIGN</state>
<view>Design</view>
<storagelocation></storagelocation>
<isphantom>false</isphantom>
<version>0</version>
<iteration>1</iteration>
<previousversion></previousversion>
<item_type>BOM</item_type>
<item_group>SA</item_group>
<item_source_supply>AS</item_source_supply>
<targetid>00000006</targetid>
Brian Sullivan
PS Error Message of HyperLink With Entry is:
Windchill Error:-- Object "wt.part.WTPart>15659029" is not persistent.
For New Link
I have it working going to the Object Record (changed VR to OR) in the Information Page HyperLink Path,
800.800.1714 x3139
Somebody smarter about this can say why, but if you change VR, "virtual
reference" to OR, "object reference" then the link will likely work.
Al
V is actually for Version reference.
It finds the Revision, then finds the latest Iteration in that Revision.
