I am using Windchill PDMLink Release 11.1 and Datecode with CPS M020 CPS29
I'm not able to import and export the BOM from production to test environment.
Import started...
Started object creation process...
Object number D000000000027 exists with the UFID that is different than the UFID from XML
Object name Ball bearing oval flanged units-FYTB 25 TF exists with the UFID that is different than the UFID from XML
Object number D000000106832 exists with the UFID that is different than the UFID from XML
Object name STEEL HEX FLUSH INSERTS HHSM-R exists with the UFID that is different than the UFID from XML
"WTDocument: STEEL HEX FLUSH INSERTS HHSM-R ( D000000106832 ) A.1" cannot be imported because the folder "/Default/BOP/Fasteners" does not exist in the context "Oven".
Object number 1000000471196 exists with the UFID that is different than the UFID from XML
Object name PLATE exists with the UFID that is different than the UFID from XML
Object number 1000000043473 exists with the UFID that is different than the UFID from XML
Object name SHAFT exists with the UFID that is different than the UFID from XML
Object number 1000002555898 exists with the UFID that is different than the UFID from XML
Object name - exists with the UFID that is different than the UFID from XML
Object number 1000000043769 exists with the UFID that is different than the UFID from XML
Object name STUD exists with the UFID that is different than the UFID from XML
Object number 1000000043212 exists with the UFID that is different than the UFID from XML
Object name BUSH exists with the UFID that is different than the UFID from XML
Object number 1000000902097 exists with the UFID that is different than the UFID from XML
Object name SMT SECTION exists with the UFID that is different than the UFID from XML
Object number 1000000471197 exists with the UFID that is different than the UFID from XML
Object number 1000000902094 exists with the UFID that is different than the UFID from XML
Object name STD PIPE exists with the UFID that is different than the UFID from XML
Object number 1000000656250 exists with the UFID that is different than the UFID from XML
Object number 1000000043474 exists with the UFID that is different than the UFID from XML
Object number 1000000043234 exists with the UFID that is different than the UFID from XML
Object name LEG exists with the UFID that is different than the UFID from XML
Object number 1000000010927 exists with the UFID that is different than the UFID from XML
Object name din7980-10.prt exists with the UFID that is different than the UFID from XML
Object number 1000000013881 exists with the UFID that is different than the UFID from XML
Object name iso4032-m24-8.prt exists with the UFID that is different than the UFID from XML
Object number 1000000048650 exists with the UFID that is different than the UFID from XML
Object name FASTENERS exists with the UFID that is different than the UFID from XML
Object number WT00000095540 exists with the UFID that is different than the UFID from XML
Object name RAW MATERIAL exists with the UFID that is different than the UFID from XML
Object number 1000000017209 exists with the UFID that is different than the UFID from XML
Object name iso7040-m5-8.prt exists with the UFID that is different than the UFID from XML
Object number 1000000043242 exists with the UFID that is different than the UFID from XML
Object number 1000000026988 exists with the UFID that is different than the UFID from XML
Object name BEARING exists with the UFID that is different than the UFID from XML
Object number 1000000010051 exists with the UFID that is different than the UFID from XML
Object name iso10642-m5x12-8_8.prt exists with the UFID that is different than the UFID from XML
"WTPart: LEG ( 1000000043234 ) A.5" cannot be imported because the folder "/Default/Nem Designed" does not exist in the context "Oven".
"WTPart: din7980-10.prt ( 1000000010927 ) A.2" cannot be imported because the folder "/Default/BOP/Fasteners/DIN" does not exist in the context "Oven".
"WTPart: din7980-10.prt ( 1000000010927 ) A.2" already exists, but has a different value for the attribute: "Cabinet/Folder"; existing value: "/Default/PENDING", new value: "/Default/BOP/Fasteners/DIN".
"WTPart: iso4032-m24-8.prt ( 1000000013881 ) A.2" cannot be imported because the folder "/Default/BOP/Fasteners/ISO/ISO4032" does not exist in the context "Oven".
"WTPart: FASTENERS ( 1000000048650 ) A.6" cannot be imported because the folder "/Default/BOP/Fasteners" does not exist in the context "Oven".
"WTPart: RAW MATERIAL ( WT00000095540 )
Hi @Shashwath
Solve each issue mentioned in the error log.
Create the appropriate folders/produccts/lifecycles
remove any UFID definition in your source xml files.
PetrH
Any issue will trip up the load. It seems like some data already exists in Test and the folders specified do not match between systems. You can change those or clear those columns in your input file.
I have commented the Tags in XML still issue persists.
Can you elaborate / share any related file. So i can try?
Hi @Shashwath
PetrH
