I need to change the Solr admin password
Version: Windchill 12.0
Use Case: I need to change the Solr admin password
Description:
Team:
I need to change the Solr admin password, as discussed in another question.
Thanks Marco for finding an article https://www.ptc.com/en/support/article/CS353251
But it has at least two bugs in it:
- bad path for jetty-util. OK, I found that one level lower, in the ext directory.
- It says I should edit realm.properties, but I don't see any such file.
Do I need to edit realm.properties? Which directory should I put it in?
What is the correct xconfmanager command?
Here is the previous question
https://community.ptc.com/t5/Windchill/change-the-Solr-password/m-p/961350#M81210
Thanks !
