Hi @vmhala , did you get the solution for this question ? I myself came across a similar use case where I need to make the IBA hide from advance search criteria drop down for most of the users and only one particular role assigned user will be able to see that IBA in drop down. Kindly help if you got the solution other than Profile option.
Hi @SJ_10076963
Generally there is no solution. You can remove the IBA from the search criteria in general for all users, but it is not possible to set the availability by a group or user.
PetrH
Hi @SJ_10076963
PetrH
