Screen display issues when moving the WGM window from monitor to second one when using two screens with different resolution (4K vs FHD).
Workaround: Overrider high DPI Scaling behaviour performed by application ( as described in CS306121)
Please rework Workgroup Manager Application to natively support proper high DPI Scaling behaviour.
Hi @MM_10750553,
Thanks for the idea. You should consider posting an idea on Windchill Ideas (ptc.com) and other community members can vote for it and comment on it there. There will be a series of questions when you post to help you better document your idea for product managers.
Hi @MM_10750553,
Thanks for the advice Andrew. Idea has been posted, the supplied link was helpful. 👍
Workgroup Manager - native support for proper high... - PTC Community
