ILINK EXPORT/IMPORT Don't Work
Highlighted
Newbie
Ilink guru's
We are trying to export some files from an Ilink workspace to a local hard
disk. We highlight the file we want to export, set the drive and folder we
want and nothing happens. I know I've seen this problem before, but can't
remember what the fix was. We are running Ilink 3.3 M021. TIA
Don Heihn
Senior Designer ? ProE Administrator
Southwest Research Institute
6220 Culebra Road
San Antonio, Texas 78238
210-522-2894
Email: -
Highlighted
Re: ILINK EXPORT/IMPORT Don't Work
I opened a call last September where import/export would not work if Pro/I
was installed on a network drive. M022 was solved this problem.
Highlighted
We have Intralink 3.3 M021 running with ProE on a network drive and
import/export works fine.
Mike Foster
Able Engineering
Highlighted
As does Kenworth.
No error message? You click "OK" and it just sits there waiting for you to
click it again?
