INFO Logging
Highlighted
Newbie
INFO Logging
does anyone know where the INFO logging setting is? i need to turn it off i am getting too many
2009-03-04 09:34:06,906 INFO [SimpleTaskDispatcher0] com.ptc.windchill.uwgm.proesrv.StandardRequestDispatcher
entries in my MSlog file. i just want ERROR entries.
5 REPLIES 5
Highlighted
INFO Logging
Apart from periodic health summaries and a few other targeted
exceptions, the intent of Windchill's logging in R9 and higher is to log
only errors (and a few serious warnings).
I'm not sure offhand why this info logging is being done (e.g. whether
someone hard-wired setting this logger's level to INFO in the code or
whether it is just a bad out-of-the-box configuration), but I would open
a call on this and demand that this be fixed as this behavior is not
inline with the intent of our product's logging.
Jess Holle
> -----End Original Message-----
Highlighted
INFO Logging
I was able to find this in the codebase folder:
C:\ptc\Windchill_9.1\Windchill\codebase\loggers.html
PTC is using log4J (YES!!!!). With the right logger name, you should be
able to change the log level of the logger specifically.
See more info here:
Highlighted
INFO Logging
Try log4jmethodserver.properties or log4jwebapp.properties in
codebase\web-inf directory.
Highlighted
INFO Logging
> be able to change the log level of the logger specifically.
Unless someone hard-coded a "logger.setLevel(...)" somewhere
inappropriate in the code.
Of course there are some legacy xxxx.verbose, etc, properties in
wt.properties for which we intentionally do a logger.setLevel(...) for
the new log4j logger that corresponds to the old verbsoe output.
Jess Holle
> See more info here:
Highlighted
INFO Logging
Hi Stephen, Try the following url
http://
<hostname>/Windchill/servlet/WindchillAuthGW/com.ptc.core.logging.remote.Logger/config
and change the following property to ERROR or WARN
com.ptc.windchill.uwgm :: WARN
Prathap
