Hello folks,
Can you help in providing the needed APi's in identifying the CAD part to be a sub-type of HARNESS.
I am able to do it for a SHEET METAL via epmDoc.getdocSubType () ...., where as it retuns NULL for HARNESS parts.
Has any one face a similar issue ,pls provide your suggestions,
Sriram Rammohan
Thank David , do you mean to say to set the attribute in Pro-E tool kit identifying the obj as Harness and then retiving the obj in WC using IBA , etc and so ?
