Hello I am a new user for Creo and windchill,
Is there any solution to show the windchill check in, check out state in 3D view,
Yes there is a inner brower we can check the inforamtion in a big table, its easy for small project;
But for large project, the table is not very easy for human be .
So if there is any solution to show the state in 3d window, by color?
Or some special icons use in structural tree?
Thanks in advance!
Are you possibly asking if the check out status, etc. can be seen within Creo Parametric while working on a 3D model? If so, the answer is:
- not visible in the 3D models themselves
- one can add columns at any time to the Creo model tree that lists this along with other info from Windchill
Look at adding columns to the model tree.
https://www.ptc.com/en/support/article/CS148947
Please provide an example of what you are asking for?
In Windchill browser, you can see the state of all parts in a view of the folder that holds the files.
In the Structure tab of an assembly, the state is shown by default.
Thank you @BenLoosli ,
I think its version problem,
My creo need add colmun by manual as @MikeLockwood show in his answer.
Thank you @MikeLockwood , Although my English is bad, you still get what I want to ask for.
and I think can check the information in model tree is an acceptable solution.
Thanks very much!
