Ilink3.3-m22 can't start - "Failed to take or refresh license".
Watch for an update shortly after 2:30 Pacific time. They are making a
go/no-go decision then.
TS Bulletins
Intralink 3.3 Refresh License Issue from May 3rd 2011
PTC has identified a software issue affecting all Pro/INTRALINK 3.3 installations, starting May 3rd 2011.
Specifically, this time-based issue prevents Pro/INTRALINK clients from obtaining a license from the license server, returning the error: "Failed to take or refresh license". The issue does not impact Pro/INTRALINK release 3.4.
PTC has prepared a patch to correct this issue, which is available here:
Tested it and it works. I'll make no other evil remarks. I wonder if we'll
be on 3.3 in 5 years or if loosing a day from so many people is enough to
move us to 3.4.
regards,
Alfonso
I have problem with download the cure.
I see next note only - "You do not have permission to view this
directory or page using the credentials you supplied"
Send me please the new dll
TIA
Re: Ilink3.3-m22 can't start - "Failed to take or refresh license".
Its happened again. On Monday the 12 June 2017 it reached the 2233 day limitation.
Any Chance PTC will create a new patch?
The problem is back again on 12th June.
Yes, we still use Intralink after all these years.  Intralink and ProE do what I need to so we didnt upgrade because we had permanent licenses anyway.  The data migration from Intralink to Windchill sucked so much we never got it complete and working.
What are my options for getting Intralink running again?  Changing the client date back and forth does work but is a pain to do.
Any chance of a new DLL to reset the date problem another 6 years?
Cheers
Tarquin
