In PTC Windchill Quality Solutions, we are getting TCP error code 10061. pls resolve the issue.
This issue typically occurs if your database is not connected.
You could check our support portal for the following article.
Article CS192106: "Error "Could not connect to net.tcp://<host-name>:xxxxx/Relex.Security/IAccessManager" upon starting Windchill Quality Solutions Enterprise Edition "
Please follow the link below to access it.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS192106&source=emailshare
Best regards
Markus
In PTC WQS11.0, when we try to get report from report wizard, it showing error that "printer not activated, error code -41". Pls help to resolve the issue.
-Viswanatha
